August 25, 2022
The traveling salesman problem (TSP) is a popular NP-hard problem that tries to answer the following question: “Given a list of cities and the distances between each pair of cities, what is the shortest possible route that visits each city exactly one time before returning to the city of origin?”.
Being first introduced in 1930, the TSP has been an intensively studied optimization problem ever since. Even though the TSP is a computationally difficult problem, by now there are many exact algorithms known that can be used to solve instances with up to tens of thousands of cities completely. Even problems with millions of cities can be approximated with a small fraction of 1%.
Today, the TSP is applied in instances such as planning, logistics, and the manufacture of microchips.
The goal of this application is to showcase some of the approaches to the TSP in the VIKTOR environment. While no new approach is developed in this application, the app gives you the opportunity to play around with different algorithms to try to get the best solution for a generated topology.
In the application, you can choose between two different topologies:
For each topology that you generate, storage is produced. This is done by creating a hash with the coordinates of all the cities. In this storage, the shortest known distance over all your runs is saved as the topology high score. For each topology that is run, you can compare the determined distance with the high score.
The application contains three different algorithms, some well-known, some lesser known, that have previously been used to solve the TSP. If you switch between the algorithms, you will see a different explanatory text appear that provides information on the specifics of the corresponding algorithm. Additionally, all the input variables contain a text box with a description matching the algorithms.
Here, you can see a small part of the Python code for the self-organizing maps:
1def self_organizing_maps(
2 cities: np.ndarray, iterations: int, learning_rate: float = 0.8, popSize: int = 100, decay: float = 0.0003
3) -> Union[list, list, list]:
4 """Solve the TSP using a Self-Organizing Map."""
5 problem = _read_tsp(cities)
6
7 # Obtain the normalized set of cities (w/ coord in [0,1])
8 cities = problem.copy()
9
10 cities[["x", "y"]] = _normalize(cities[["x", "y"]])
11
12 # The population size
13 n = popSize
14
15 # Generate an adequate network of neurons:
16 network = _generate_network(n)
17
18 routes = [_get_route(cities, network).values.tolist()]
19 distances = [path_distance(problem[["x", "y"]].to_numpy())]
20
21 for i in range(iterations):
22 # Choose a random city
23 city = cities.sample(1)[["x", "y"]].values
24 winner_idx = _select_closest(network, city)
25 # Generate a filter that applies changes to the winner's gaussian
26 gaussian = _get_neighborhood(winner_idx, n // 10, network.shape[0])
27 # Update the network's weights (closer to the city)
28 network += gaussian[:, np.newaxis] * learning_rate * (city - network)
29 # Decay the variables
30 learning_rate = learning_rate * (1 - decay)
31 n = n * (1 - decay)
32
33 # Adding data for the frames
34 route = _get_route(cities, network)
35 problem = problem.reindex(route)
36 distances.append(path_distance(problem[["x", "y"]].to_numpy()))
37 route = route.values.tolist()
38 routes.append(route)
39
40 return routes, np.arange(0, iterations + 1, 1).tolist(), distances
You can now download the full Python code from our GitHub repository or sign up for a free VIKTOR account to use it in your own applications!
